slipperential availablility
hey when is the 1/8th slipperential available? what spur will come stock? will it need new dogbones / center cvds? this is the last piece i need to finish the conversion.
thaks jim |
Did Like Me And Do Your Own One, With Metal Saw, Dremel And Press Drill!!!!
Hey David, got pics of yours?
I want to see what you made! |
i modded a dominator slipper to fit, and i like handling ,but the combo of slipper and diff are there just for another option to try. so i would get one just for options.
mike, can you give me some insight on the questions above thanks |
Yesterday, i've de-anodise the chassis for a rough, factory look. Today, i'll go at the machine shop to a little milling job on the mount. I'll have a 46T spur on the center direct drive unit, 22T drive gear, 40T revo slipper gear and a 18T pinion on the motor. I estimate a top speed of about 42m/h with my Neu 1515, 1Y and FlightPower 4s, 5000mAh. I'll keep you informe of my project:intello: Bye! David |
| All times are GMT -4. The time now is 12:21 PM. |
