RS4 Pro 2 with 2-speed transmission and 24 inch rims LOL
3 Attachment(s)
Hi all,
Here are a few pictures of my RS4 Pro 2 with 2-speed transmission and 24 inch rims (RC scale of course). I will stuff one of my Hacker B50 in it and hope for the best. I stripped the set screw and I still have my old brushed set up in it. I hope you all like it. |
3 Attachment(s)
And the rest.
Thats a nice setup! Does the Pro2 still use the ball diffs? The ones in my RS4 pro did not care much for brushless power.
I just gave my RS4 Pro w/mamba 7700 to a good friend of mine for Christmas (I'm not sure why) but I kind of miss it now so maybe time to build a new TC. Be sure to post a video of melting those drift tires off when you get the Hacker installed. |
How much ground clearance do you get (or gain) with that set up? I was thinking of trying the super rs4 tires on my rs4.
I was going with the Hacker B50-6S, but it was just too fast so I decided to go with the B50-8S. I just finished adjusting 2-speed. The VXL ESC seems to be working good with the Hacker.
RS4 2-Speed going back in the basement. I have no clue what went wrong, but second gear fried. Everything was going good with the adjustments, but after I mounted the ESC, battery and receiver, I hooked the ESC to the motor gave it some throttle and found that some how the second speed spur gear was bent. Now I can't even take ot the clutch as the system doesn't move like before.
| All times are GMT -4. The time now is 10:41 AM. |
