Emaxx Transmission Spur Wobble
I have the Emaxx single speed transmission on a G3R chassis. Converting back to stock emaxx spur, 32pitch pinion etc.
When I tighten down the nylon nut for the slipper clutch it makes the spur gear offset. So when you spin it, you get wobbling action. Way too much for a brushless setup. When you loosen the nut, the spur somewhat "flattens out". I watched the input shaft and it doesn't wobble. What gives? Anyone know a fix for this other than two washers, one on either side of the nut. Thanks. |
That is common with the stock spring. There is a suitable replacement but can't remember what vehicle it is from.
You could try this:
http://www.rc-monster.com/forum/show...hlight=slipper I am getting ready to try it on one of my single speed trannies. |
Is the spring necessary?
why not buy a sprong? heres one for $40.
http://cgi.ebay.com/VERY-RARE-STROBE...QQcmdZViewItem |
Urban Dictionary Defintion. Ha 2. sprong To Unleash the act of setting Angry Geese and other Aquatic Animals Upon Someone No, really where can I get one? |
Sweet. thanks for the link.
they are now discontinued. id snatch this one up and quick!!!
Try this out:
http://www.rc-monster.com/forum/showthread.php?t=9341 Both modifications work great. Cheaper then the real stuff.:whistle: |
BL_RVO
why not buy a sprong? heres one for $40. http://cgi.ebay.com/VERY-RARE-STROBE...QQcmdZViewItem Will that work with the stock emaxx spur? I have the strobe setup but it's limited to 9t pinion and 51t spur (that i know of). And lamo towerhobbies is out of 9t mod1 pinions. |
IIRC, it will accept all sizes.
two flat washers on either side of the spring worked. Huge difference.
mgt spring does the job - fixed almost all of my wobble - $2 fix
| All times are GMT -4. The time now is 04:22 PM. |
