Savage Conversion!
K i am getting the FLM kit and currently have a MM with 8xl and a 4s 5000hv max amps pack. My question is what pinion to get to go as fast as possible with out overheating my electronics. I used the speed calculator and an 18t pinion will get me around 40mph. I have the 3 speed in the truck so just wondering what everyone else is running.
Remember there are 3 different size spur gears available for the savage which are cheaper then pinions. You can use those to change your gear ratio to find the perfect point. I bought a 14t, 16t and 18t pinion (my savage has different diff ratios compared to stock) and with the 3 different spur gears I basically have any gear ratio. I put the FLM kit together last night and I was so impressed. I couldn't believe how well it went together. You won't be disappointed.
Glad to hear the FLM kit is worth the money. Upon looking at it though i felt the price was really good even if the kit was not perfect. As far as the three spurs i have the metal one that is 47 tooth and would like to keep that for it is metal and will use a hardened pinion to take the metal to metal contact. Thanks for the reply. Oh cant wait for the MMM for i will put that in and have some real power.
| All times are GMT -4. The time now is 02:20 AM. |
