Having 2nd Thoughts...(Help Me Choose)
I was originally planning to get the Mini MGT but Im having 2nd thoughts. My bro is gonna be buying a Savage X 4.6 to convert to electric. I now want something equal in size or bigger. I was looking at the LST2 and the Cen GST 7.7/Nemesis. What one would you rather have? The cen has its ups/downs and the losi has its ups/downs. Im looking to run 5s with the MMM ESC and a possible Neu/Lehner motor. Any idea's?
Thanks |
Here's some pics...
LST2 http://jennys-rcsports.com/images/1546-1.jpg GST 7.7 http://www.extremerc.ca/items_images...1981header.jpg |
from what i understand, both will be bigger. lst 2 will out handle the savage, gst will run over the savage if you can get lucky and catch him.
I am going to convert later this year a XTM Monster MT. Its bigger then all the above mentioned and the weight didn't look to bad. I think around 13lbs.
I don't think you realize just how big the genesis is. It's HUGE. Infact, 5s may not even be enough for it without running too hot. I would def. Do the losi if those are your only choices.
Their is no budget as of right now so thats why I have the GST 7.7 on the list.
If you go with losi, look at the aftershock, especially if you plan on converting it. amainhobbies has it for 309$ and they always have 25$ off coupons.
The aftershock is nearly the same as the lst2, and with the upgrade kit 100-120$, you can basically make it into a lst2, only with plastic shocks instead of aluminum. You can then spend the 300$ you save on other upgrades, or your electric conversion. Worth taking a look. |
+1 on the aftershock, no need to buy the lst2. You could also buy the raminator or the mega baja, one of them even has a dsm radio setup.
What's the Amain code? I might need one soon :lol:.
If Your Order Totals: You Save! Refer to Coupon#
$100.00 - $149.99 $5.00 DPPMAR85 $150.00 - $249.99 $12.50 DPPMAR812 $250 or more $25.00 DPPMAR825 good at amainhobbies until apr 30, 2008 |
| All times are GMT -4. The time now is 12:54 AM. |
