Help!!! A drive yoke that will work with the 8mm pinion...
.... Hi guys, as the title says.. I am looking for a drive yoke that will work with my Hot Bodies Lightning Pro pinion (8mm) in combination with the RD Logics drive shaft (http://i1.ebayimg.com/03/i/07/6a/8c/17_1.JPG).
The drive yokes that came with the center shafts were 6mm (internal diameter)... so I went ahead to try and open them up myself to the 8mm required to fit Hot Bodies Pinion... this did not work out very well.. the damn things are so hard, I went through two drill bits trying to open the first one. Any help will be appreciated... Alien |
Pretty sure this is it.
http://www3.towerhobbies.com/cgi-bin...&I=LXJBE9&P=SM You can go to Hotbodies web site and pull a manual for the lsp and have a look, but I am sure this is what I bought. |
Hey lincpimp,
thank you so much for your help man... looking at thet specs on that link you sent... it's a perfect match (8mm ID on both ends)... I just found a set on ebay that I think i'll grab tonight. Alien |
No problem,glad I could help.
I had the same issue with my racebomb, and had to find these thru the lsp manual. |
| All times are GMT -4. The time now is 11:04 PM. |
