-   -   Big Enough Stator For Direct Drive? (https://www.rc-monster.com/forum/showthread.php?t=10606)
Takedown 03.07.2008 02:10 PM
Looking to buy a powerful outrunner which has a stator size of 52/30.
Im wondering if this will be able to power my warhead on 5s 30c-60c lipo and if so how fast do you think it will be able to go with these specs...
Diff ratio- 3.307
Tire diameter- 5.311in (E-Savage Tires)
Weight of truck with conversion- 12.1lbs
I hope you guys can help me out with this because Im looking to buy this soon.
Takedown 03.07.2008 02:21 PM
BTW: The truck Im converting is a Warhead.
Pedebeater 03.08.2008 12:00 AM
Why don't you just plug it into the calculater? You did not specify the kv.
http://www.scriptasylum.com/rc_speed/_top_speed.html
tashpop 03.08.2008 12:48 AM
just speculating, he doesn't know real amp draw to know if the motor is going to do it or not. i'm not too keen on outrunners or direct drive.
MetalMan 03.08.2008 02:37 AM
I think the motor could handle it fine. My only concern is whether or not the truck can handle it... Outrunners are HARD on diffs especially compared to outrunners, because of their huge moment of inertia.
Takedown 03.08.2008 11:31 AM
The diff ring gear, bevels and planetary gears are all hardened steel. It'll hold up to the power with ease.
Takedown 03.08.2008 11:32 AM
The KV of the motor is 280kv. Sounds very low but should be prefect. I really need sike's help right now.
Takedown 03.09.2008 12:54 AM
Another question for you guys... You think a Jeti ESC or even a MMM will handle a 14pole motor with proper settings on 5s lipo?
BL-Power 03.09.2008 05:28 AM
Why don't you take a Kontronik Jazz 80-6-18? The Jazz controllers are working really nice with outrunners, cogging isn't existing: http://picasaweb.google.de/Brushless...87508891729186
Takedown 03.09.2008 09:33 AM
Hey BL-Power, Ive heard that even though kontronik is great and all that theirs much better out their. I really would like to stick to the Jeti I have right now.
BL-Power 03.09.2008 10:57 AM
Oh, i didn't knew that you already own a Jeti controller. :oops:
