-   -   Temp? (https://www.rc-monster.com/forum/showthread.php?t=10608)
damon 03.07.2008 04:24 PM
Temp?
What motor and ESC temp should I be aiming for with a 12020/7XL on 14 cells? At what temp should I get concerned? Thank you
lincpimp 03.07.2008 05:53 PM
If you can keep the motor temp around 160 you will be good, any more than 180 is too hot. Esc temps vary, but I feel that 140 is about as much as I ever want to see. That esc should be fine, but you will want to gear the 7xl down a bit, with 14cells it will be turning around 38k rpm.
damon 03.07.2008 11:07 PM
Thanks Lincpimp. I had a 18 tooth, and I think I will start with a 16. Thanks!
18 tooth on a 8XL
