-   -   I Need Motor Help!!! (https://www.rc-monster.com/forum/showthread.php?t=10675)
satttheman 03.10.2008 09:02 PM
iight guys im doin a muggy conversion and i was goin to just do a 10xl but my original plan was for a 1521/1y. but now im confused decisions, decisions, decisions. well anyway i need some help im goin to run 6s no hv setup for me not yet. but my motor choices r the 10xl, a 1521/1.5d, a 1521/1y, or the 1527/1d( i kno its a high kv motor its like 2100kv and will prolly draw crazy amps but it should still be a torque monster) have a neu 4900 25c that will be in the truck and it a decent battery so it needs a good motor. coming guys help me out here.
suicideneil 03.11.2008 04:25 PM
Racing or bashing?
6s esc limits your options to a handful of controllers- Quark, MGM, Jazz maybe, or the MMM, unless you can live with a forwards only + mech brake setup = airplane escs at your disposal.
I think a lower kv like about 1500-1700 for 6s, then with those larger Neu 1521 motors you will have greater torque for higher gearing, and speeds easily in excess of 40mph+, with cooler temps and longer runtimes to boot.
The battery you have is a 6s item I take it?
tashpop 03.11.2008 08:33 PM
i really don't know why there would be a toss-up between the nue motors or a feigao. seems like an easy decision if you're willing to spend the money.
satttheman 03.11.2008 09:29 PM
well at first it was easy at first just get the neu and then i became hard when child support hit me for almost 330 a week but im thinkin since im goin to do it do it right but im thinkin the neu 1521/1.5d the 1860kv do u think this would be a good 6s motor or should i go with the 1521/1y that mike sells
bdebde 03.11.2008 09:39 PM
I think either motor would be great, it may boil down to what you can find in stock.
satttheman 03.12.2008 05:46 PM
ordered the 1521/1y i hope i like it i wanted to 1521/1.5d so ill see how it is
satttheman 03.13.2008 04:22 PM
http://img2.putfile.com/thumb/3/7214163736.jpg
http://img2.putfile.com/thumb/3/7214163738.jpg
muggy mounts are available
satttheman 03.20.2008 02:14 AM
i think the 1521/1y was a great choice check out the vid
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/bo7GdkNpKAY&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/bo7GdkNpKAY&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
xcntrk 03.20.2008 08:20 AM
Great vid!
I’m curious how that crazy torque in your vid translates on paper (using BrianG’s calc)? What’s your muggy’s front/rear diff gearing and tranny gear ratio? I’m interested to see what your calculated mph and ft-lbs torque equal versus what was seen in your vid…
~Thanks…
satttheman 03.20.2008 10:44 AM
the muggy diff ratio is 4.09
the pinion was 22
the spur is 46
bdebde 03.20.2008 10:49 AM
Hard to believe it is 22/46 (according to vid) gearing!
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.09 : 1
Total Ratio: 8.55182 : 1
Tire Circumference (inches): 17.91 inches (454.84 mm)
Total Motor Speed: 35009.4 RPM
Vehicle Speed: 69.42 mph (111.51 km/h)
Effective Speed Rate: 3.13 mph/V (5.02 kmh/V)
Estimated Adjusted Speed: 63 mph (101 km/h) - 10% loss
Effective KV Value: 1577
Final Torque: Amperage not specified...
Final Power: Amperage not specified.
xcntrk 03.20.2008 11:27 AM
Strange, that doesn’t seem to add up…
At max voltage the 1521/1y is rated to draw 75amps. With your configuration (at least according to BrianG’s calc) that’s only 2.86ft-lbs torque with a crazy top speed of 63mph. The smaller torque number is what’s strange. Your vid clearly didn’t look like only 2.8ft-lbs torque as you were easily pulling the front-end a decent speed.
bdebde 03.20.2008 01:12 PM
max amps = watts/your voltage; more like 135 amps
xcntrk 03.20.2008 01:44 PM
^not this again. Nobody can seem to explain this to me. Sorry for the noob lack-of-understanding here; but how can you calculate your watts without having an amperage figure?
Where is the 2997w figure coming from?
bdebde 03.20.2008 01:57 PM
Max watts of motor is 3000, But to be accurate you would need an eagle tree or other accurate amp reading.
