Quark 125b
Since Mike is out of stock on the MGM's it looks like I'l be ordering a quark 125b tomorrow. Since it's bec output is only 5v I plan on using an ubec instead of the internal bec.
My question falls to the LVC. The manual only shows up to 3v/cell lipo cutoff. I want a safety barrier of 3.2v/cell Id there a way to make the internal accept this or will i have to use an external lvc? |
Nope. 3.0v/cell is the highest you can go. You can set it lower than 3.0 if you want.
I wouldnt worry about it. I have been running 2 of the Quarks (3 if you count the 80B also) for a long time and I never had any problems with the LVC running the cells to low. |
for sure get the heatsink tough. you will need that
| All times are GMT -4. The time now is 08:54 AM. |
