mbx5 + mamba max + lipo 4s + WHAT MOTOR ???
hello,
i had a project whith the mugen mbx5, the mamba max (100A max), a lipo 4s (limited at 80A), and i don't know what motor choose ... what can i put on my car? and I dont whant feigao's motors what do you thing about the align 600XL in 4s whith gear in 16th ? it's good or not ? thanks |
I believe 4s is a little light for 600xl -
1509/1.5Y 2400 1512/2D 2550 1512/2.5D 2050 1515/1Y 2200 Or try briang's motor selector http://www.scriptasylum.com/rc_speed/index.html |
Your 80 amps max 4s lipo will be the limiting factor. Gearing over 35mph will most likely overdraw the batteries, regardless of the motor used. The align xl is a decent choice for a motor, however the 16t pinion will not get you much more than 30mph. The motor kv of 1670 is too low for 4s, total rpm will be around 24,000. I would suggest a feiago 9xl, but you do not want a feigao. Any specific reason?
1512/2D 2550 --> 125A , it's too much for my lipo and esc ! 1512/2.5D 2050 --> maybe 1515/1Y 2200 --> 110A, it's too much for my lipo and esc ! and where buy this NEU motors ? here they are "out of stock" |
I don't know explain this in english, sorry and OK for the align, it isn't good what do you think about hacker and lehner motors ? or others |
You could try one of the Mega ACn22/30/1E, ACn22/35/1E, ACn22/45/1 or 1E.
but where buy this motors ? |
Hacker are good but too much $'s new
Lehner are great and two pole so will be really nice with MM Those amp ratings are a little over-rated - any motor will pull what it can under load. Just get the load right and you'll be fine... |
http://www.youtube.com/v/EAtcnCTdjAI&hl The last time I drove the truck it only spiked at 75A. |
thanks but where buy mega motors (directly link) ?
and where to buy Neu 1512/2.5D ? (I think I'll take this motor) |
ok thanks, but in France , nobody use this motors, 1/ so I want to know, if they are good motors, reliable and sturdy ? 2/ at the nivel of power, how they are ? 3/ I see the on the front of this motors, there is big ventilation, so all dust go in the motor, no ? 4/ and if http://www.megamotorusa.com are serious ? thanks |
2. The Mega ACn22/30/2 is in my truggy (MBX5T) smaller than the other, but powerful. 3. Get some thin foam or fine screen mesh and wrap around the opening. 4.http://www.megamotor.cz/new/script/m...5&language=eng |
and I think i 'll take the ACn22/35/1E he is good for my buggy in 4s ? the axis for gear is 5mm ? thanks |
| All times are GMT -4. The time now is 05:44 AM. |
