Losi LST2 Brushless
I was thinking about converting an Lst to brushless(didn't want to buy from that FineDesign guy) and wanted to use a Neu motor with a 6s lipo and since the truck has mech. brakes, use a Castle HV 125. Would use Monster Pro if the Castle doesn't work, anybody know which Neu i should use?:whip: Maybe Mike could make me some good motor mounts so i don't have to.:lol:
The CC 125 is not the HV model, its only good for 6S. The HV model is rated for 12S.
So on the airplane models (HV110) you can use the same setup as the MM models? Like forward/brake/reverse (proportional w/reverse lockout)? It that's the case why haven't I bought one!
None of the cc air escs, inc the hv110, have proportional brakes. You must also use a pixstix adapter so that they will work with a wheel radio.
i have been interested in this also , now that i have mech. brakes on my truck i may try this, anyway can someone post a link to a pixstix, i couldnt find it on tower , and dont know where to find one, thanks
HobbyCity Turnigy 6S-100Amp ESC is working great in my Brushless LST on 6S and 9XL... $65 ESC + $14 PiStix.... works great!!
Screw-Up
Pxstix is available from rchydros, who make it.
Or get it from offshoreelectrics.com. |
Found it, that website is on my favorites, right under my nose.:lol:
Feigo 7XL Motor
Do ya'll think that a Feigo 7XL motor would be a better choice than the Neu 1521?:intello:
I have a Fine Design XLT1 in my LST2 which is basically a 7XL. I just ordered a Neu so I'm hoping it'll make a huge difference. I got used to the XLT motors and want more now.:oh:
I have an aftershock, and intend to use a KB 45 12xl motor on 8s-10s lipo. Leaving the stock 2 speed and using Mike's 2 speed adapter, which I had him bore out to fit the KB 6mm shaft.
Going to leave the mech brakes and use a CC hv85 esc with a pixstix adapter. Most likely going to use a pair of 2200 20c 5s lipos wired in series. Batteries should be good for nearly 2hp, hope that is enough. I may have to buy some larger capcity 5s packs, we will see. |
| All times are GMT -4. The time now is 11:51 PM. |
