e-revo - 5s lipo - up in smoke :(
What motor again? 1521/1Y? on 5s pulled more than 125amps and smoked the Quark or did the drivetrain lock-up or something?
I remember reading another member got some dirt/debris lodged in the spur gear out bashing and it locked the drivetrain at WOT and instantly smoked the ESC… |
I think it was the Quark that smoked, right? And you had a Neu 1515/1y I think too. But that thing had some sick power. :yes:
That looked just like mine when it too put out a fabulous amount of smoke. When I went to unplug the battery, the wires from the ESC just came out.
Awww man, that's like your 2nd or 3rd controller thats gone up! I feel for ya, I think I just blew out my Hyperion LiPo somehow. I might be making it into a 3 or 2s pack. Speaking of lipos, is that a True RC pack? How do you like it?
you know hes got power if it needs that much blue smoke to run the esc :D
Bummer, hate it when RC days end with dead components.
Wat hauling #$$ before it stopped though!!! Can't wait to have an ERevo... |
I love the true RC lipo, it has never gotten above ambient temp. The drivetrain was fine, temps were air 85, batts 86, motor 115, esc fried
The motor is a 1515 1y, and lutach that is exactly what happened. I went to unplug the battery (which is ok) and the wire came right out |
I wonder why people don't put an inline fuse between the battery and the esc. Use a fast blow fuse with the esc max amp. Probably need another one for the ESCs maximum continuos amp rating, but make it a delay type so that we can still acomodate the amp spike during acceleration.
Bummer- at least it didnt go up in flames I suppose.
That's to bad about your esc, at least you did'nt have any flames. My friend smoked his MM the other day in his E8 buggy. His shot out flames thou :gasp:
I am thinking the Quarks esc fried due to internal heat, I have seen people needing to run external heat sinks and fans if they are running them above a 4s....that isnt very impessive for an esc that is suposed to be able to handle 6s....has anybody tried running an external UBEC and disable the units BEC....since I wasn't present when Dicky T's esc fried I don"t know everything that happened so its only a guess Since I went to using the CC BEC and 4 cell lipo withe the Fiegao motor the heat to the MM is almost non existent |
I had the rc-m heatsink on it, Ubec, and no fans. rc-m heatsink was mounted to tekno mount, the quark to the heatsink with arctic silver paste, and a 2 zipties around the whole thing to holed the heatsink to the mount. In previous testing runs prior to filming the esc temp never got above 125. I tested in loose dirt, asphault, grass, and sand. After a 30 minute run in sand was the hottest I had seen it was 125, and that was towards the end. I checked temps every 2 mins during the 1st 6 runs, every 5 mins during the second 6. this was the 7th run total and less than 2 mins in, poof. I'm going to call S&T here in a few mins to send it in for repair\replace. |
Ouf!! you have paddle on it:oh:
MMust pull lot of Amps:lol: |
| All times are GMT -4. The time now is 02:56 PM. |
