Y harness for dual 2s lipos, safe?
Is it ok to make a Y harness for 2 2s lipos (effective 4s?) Both batteries going into a single battery leads?
I will be using a quark monster pro but will make a Y harness to connect both batteries into the Quark single battery lead. Reason is, I run an emaxx 3905 and want to keep the batts on the sides and I have mounted my 1515 center line (single motor mount). Good idea? Dumb? |
Alot of us do it, the only downside is that it is advised to charge and balance both packs in series too. Means that you will have to make a charge harness and balancer harness. Check BrianG's sig as he has a website with all of the wiring info.
Thanks for the info!
| All times are GMT -4. The time now is 01:26 PM. |
