Problem programming MGM with PC
I've just started to use the new pc programming software and problem is its missing things like Residual Energy Voltage, Voltage of BEC, Voltage of battery at switch off. It shows Battery Type, Behaviour when battery voltage going down, Range of neutral zone.....down to --> auto brake in neutral. But nothing else after that. Does anyone have the same problem?
There is no Residual Energy Voltage, and no Voltage of BEC. Some of the blank fields like Voltage of battery at switch off only show after a run.
How do you set the cut off voltage?
all you specify is number of cells and type of cutoff - power down or slow down
Damn... Thanks for the input guys.
| All times are GMT -4. The time now is 12:55 PM. |
