Neu Energy 5000 4s balance plug to Trakpower V-Balancer
Hello all,
I am about to buy a Neu Energy 5000 4s pack and need to know which balance plug to Trakpower V-Balancer adapter I will need. I use the Trakpower balancer for my 1/10 buggy Trakpower packs and was hoping I could use it to balance the Neu 42 packs. Thanks! |
Does the balancer just have the 2 small pins, or did they give you other leads with it? if not, you will need the flightpower adapter for 2,3 and 6s and the neu-tp adapter from neu store
You will need a flightpower to neu (kokam) adapter. And most likely the flightpower adapter pack that the std v balancer is sold with, as your v balancer only came with the leads to hook to the trakpower packs. It woks great on all of my packs, and I prefer the v balancer interface to the lba balancers. The fuel gauge is cool too.
Here is the best picture I could find of it (click picture to make bigger): http://www.amainhobbies.com/product_...ducts_id/12576 Quote:
Here is what the other leads look like. You can enlarge the pic for a better look.
http://www.amainhobbies.com/product_...ducts_id/12575 This is the 4s adapter for flightpower batteries. http://www.flightpower.co.uk/Product...=FPVHR4S-VBALH Now you will need an adapter to link the battery to the 4s adapter I listed above. It will have to have a male flightpower 4s plug on one end, and a female kokam 4s plug on the other end fo the battery to connect to. I do not know where to find that adapter, but either cheap battery packs.com or maxamps.com may be able to make you one. I could most likely make you the adapter, just need to find a female kokam 4s plug, and I have not found that yet. I have a neuenergy 3s lipo and used this board with my lba charger: http://www.maxamps.com/HYP-MULTI-KOKAM.htm If you can find an adpater for the v balancer that will got to a 6s hyperiom tap, this board could be used. |
You would be better off getting this adapter
http://b2b.flightpower.co.uk/Images/...-VBALH-400.jpg And using the adapter from neu, part number NEU-TP. With that set up on my flightpower balancer, I can balance 2s to 6s neu, maxamps, and apogee batteries with no other adapters or leads. It will also do 2,3 and 6s flightpowers without the NEU-TP adapter. |
I new that there had to be an easier way, thanks bdebde. I did not know that neu had an adapter to flightpower, but it is good that they do!
Thanks for all the help so far guys:yipi: |
Sorry for all the questions and such, just want to make sure Iget setup properly the first time.
Are any of these what I need? http://www.horizonhobby.com/Products...ProdID=AGNA206 http://www.maxamps.com/products.php?cat=69&pg=3 http://www.maxamps.com/TP4S-HYP-Adapter.htm |
| All times are GMT -4. The time now is 01:57 PM. |
