mgm 16024-3 advise
hey guys looking for some help i have mgm 16024-3 esc this item will only work with the receiver pack installed to the receiver, is this the only way to run it ? i did not want to use a receiver pack. any help would be great
Either a receiver pack or external BEC; that controller has no bec built in.
the mgm 9032 that i had (now going to mgm to repair) has no bec, so it only works wit a receiver battery.
thanks bdede that helps a whole lot
The 16024 is an OPTO controller. It has no built in BEC. You will HAVE to use a reciever pack, or an external BEC. J. |
Get yourself a UBEC. It hooks between your main pack and the reciever to provide power for servos, etc. Weighs nothing compared to a rx pack. The CC BEC is a good choice. It has a 3A constant and 10A peak current rating.
| All times are GMT -4. The time now is 03:23 AM. |
