-   -   Mamba MAX on savage (https://www.rc-monster.com/forum/showthread.php?t=10986)
Vrooom666 03.26.2008 05:28 PM
Mamba MAX on savage
Any reason not to run stock mamba max ESC and 4600kv motor with 3s lipo on savage X?
i was told its bad idea as you can burn out the motor.
I am going do this as temporany postition until i got cash to buy new motor, cant you gear it down very low so it can pull itself ?
Jay
bdebde 03.26.2008 05:38 PM
That rig is far too heavy for the mamba motors. Get a larger (Fiegao XL or Neu) motor and you can use the MM on 4s with external bec. You will likely burn up the MM motor in a short time.
Maxxman 03.26.2008 06:00 PM
I run the MM in a FLM converted savage. The MM will be fine but the 4600 motor won't be up to much.
Vrooom666 03.26.2008 06:03 PM
Which Fiegao XL 7XL or 8XL for my savage.
Im aiming for good run time. not interested in top speed.
Maxxman 03.26.2008 06:08 PM
The 8xl will give you longer run times and tax the MM less but be slower. Although you could gear up a little to compensate fo the lower KV if you wanted.
83gt 03.26.2008 06:23 PM
8xl is very fast on 4s. On 5s it's pretty stupid, lol. I'd think it would do well in the savage. I don't think i'd try a 7l, I'd think it'd run way too hot. A 9xl might even be a better choice, since the savage X is going to be quite heavy.
J.
*edit*
I see you want to run 3s. nix what I said up there. You could try a 7xl on 3s, but I think you're going to want more voltage before it's over and done with.
jnev 03.26.2008 07:34 PM
I'd go for 4s on the 9xl or 3 on the 8xl. 4s is ideal though. The Mamba Max motors will burn up in no time running them in a Savage.
MTBikerTim 03.26.2008 07:38 PM
9xl, 4s, MM and a bec.
aqwut 03.26.2008 08:02 PM
I second that....
bdebde 03.27.2008 12:20 AM
I third that. :lol:
Fast5sRevo88 03.27.2008 11:31 AM
Jay
One thing i got to say; Ssssssssssllllllllllllllllllllooooooooooowwwwwwwww w!:lol:
