Quick question
I got a quick and kind of a dumb question. I am stillwaiting for my battery packs to come in so I can figure it out for myself. If you are looking at the pinion side of the motor which direction do the motors spin? I just want to make sure that when I gun the throttle that I dont go in reverse. Thanks.
The novak will spin the same direction as the stock motors. If the car goes backwards, you can turn the diffs around. If the tranny is in the same location as the stock, you won't have a problem.
Cool thanks. :)
| All times are GMT -4. The time now is 11:16 AM. |
