-   -   183Amps recorded on Rustler with 3s2p A123 (https://www.rc-monster.com/forum/showthread.php?t=11029)
snellemin 03.28.2008 02:48 PM
Using the Eagletree datalogger, I recorded a peak of 183 amps from 3s2p pack in my Rustler dragster running a 380 6L Feigao motor and a mamba max ESC. These cells are bigger monsters then I thought they were. I still need to figure out how to get the data out(layziness on my part). I cleared the logger and then forgot to save the data. Going to do it again if it doesn't rain today.
BrianG 03.28.2008 03:03 PM
What was the voltage at that current?
bdebde 03.28.2008 03:03 PM
which eagletree are you using?
lutach 03.28.2008 03:03 PM
A123 cells are awesome. My 36V pack gave me 172A of enjoyment.
snellemin 03.28.2008 03:06 PM
I think the voltage dropped to 6V or something like that. I'm using that 150A rated Eagletree datalogger. Wires were warm after my test.
lutach 03.28.2008 03:15 PM
My 10S pack was at a little over 2V as well when it went above 170A.
snellemin 03.28.2008 03:27 PM
The voltage was at 10+ when I started running. Going to measure how much juice my 2lbs camaro sucks.
I had to put the fan back onto the mamba ESC as well. It reached 205F in a hurry and the motor was about 139F after 5 minutes or so. I have to reduce the punch control to reduce the wheelies and amp draw.
othello 03.28.2008 04:14 PM
In 2p config you could expect even more from A123 cells. I see Amp peaks of 100-120A used as 10s1p (My eagletree v1 is rated for max 100A). So if your ESC and Motor is able to provide/suck 200-240A, your battery pack would provide it for short bursts. At 100A as 1p config voltage could drop to 2V (i see a range from 2 to 2.4V). It really depends on cell temperature and cable length.
From a Power point of view i calculate with a max of 250Watt per A123 cell (110A@2.25V). So 3s2p are able to provide up to 1500 Watt (and maybe a little bit more when you warm them up before driving). There is also a feelable difference in power when they come fresh from the charger as when you drive them say 1 day after you charged them.
snellemin 03.28.2008 04:22 PM
I know about the warming up part of the batteries to get more power out of them and that 250watt per cell makes sense as I recorded 1400+ watts. The measurement was taken on freshly charged packs.
What's_nitro? 03.28.2008 07:28 PM
Hey do you have the space to make it 3p? That would allow a LOT more voltage under load.
snellemin 03.28.2008 10:01 PM
I do have the space for 4p, but all that extra weight might not do me good for dragracing. I rather do 6s2p whenever the MMM gets here.
lincpimp 03.28.2008 10:53 PM
i see that you like the 380c 6l! You have definately run one harder than I have! My old one was in an emaxx on 3s, and I had it geared for about 55mph!
snellemin 03.28.2008 11:09 PM
I had the 6L in the dragster and it was impressive. I put the little hacker in there and it was only pulling 30 amps doing burnouts in my garage.
snellemin 03.29.2008 12:48 AM
I did find the file. Here's the graph.
http://i189.photobucket.com/albums/z...ustler3s2p.jpg
