What is the diameter of a 46t mod 1 spur?
Title says it all.
48mm.
http://www3.towerhobbies.com/cgi-bin...?&I=LXSKZ4&P=7
This is the 46T Spur Gear for the Associated RC8 (ASCC0600). FEATURES: Metal construction, silver in color Replaces worn or damaged spur gears INCLUDES: One 46T spur gear SPECS: Diameter: 1.85" (47mm)_ Thickness: .39" (10mm) |
Something HAS to be up with that. For mod1, the diameter is 2mm + tooth count. So, 46+2=48. I wonder if the teeth aren't as tall/pointy or something?
They vary across tower from 47 to 48.2mm...
And will they fit in between E-maxx chassis braces with the FLM chassis? I think you know what I'm getting at.
3 Attachment(s)
the diameter is twice the radius:lol: no they don't fit, they just barely hit, trimming 1mm off each side would do it, check this out-
an rc-monster center diff/motor mount for the flm e-maxx chassis. I'm the second in the world with this design. Has a 8 spider 46 tooth diff, just barely hits, minimal trimming needed, sorry about the 2 megapixel pics
| All times are GMT -4. The time now is 11:35 PM. |
