Rc8
Hi all!
I just ordered my RC8 conversion stuff. I a pretty excited here is what I got so far. Neu 1512 2D/F RC-Monster Mount RC-Monster Battery Tray RC-Monster motor end cover. I am waiting on a 4s 5000mah polyquest battery and a Hyperion DUO charger and CC BEC. I am also trying to decide if I should just order the MM or wait a couple more weeks for the MMM??? What gearing should I be looking at with this setup I would like to keep the top speed down to around 45-48mph . Do you think I need to dremel the fins slightly to give me a larger range of gearing options?? Thanks! |
If you think you are sticking at 4S and with a buggy a MM / UBEC and extra Cap will work fine... However new this will set you back 115+20+10=145 a MMM is due (fingers x'd) EOM and should be 180-200ish and you won't need the BEC/Cap...
The Duo's pretty pricey maybe easier just to get a smaller charger - ATB |
Not a problem on the price of the MM but is there any info on putting the extra cap on it?? also If I recall isnt there someone on here that will mod them for you??
THanks! |
Also do you think I am better off gettin the Hyperion EOS 610i NET charger. I really just want something that will be able to charge as quickly a s possible
You have a 5000mah battery at 1c thats 5amps a EOS5i at $50 would do the job...
A bigger charger won't help... I would look at a 606i |
The 606i is limited to 50watts. I believe the eos5i is also only 50watts. If you are using 4s I would stick with the 610.
I have the 610i and it works great. Excellent charger.
Yeah I am prob going to get the 0610i DUO because I am probably going to pick up more then one Lipo..
What about the gearing where should I start?? Thanks! |
Well, if I recall with the RC Monster motor mount I think a 15T pinion is the smallest without mods you can do. For me, with a 2.5D motor it appears a 17T pinion is a starting point, going to a range of about 19 - 20T pinion. I would say for you, maybe start with a 16T pinion to start with.
If you are set on ordering a Mamba Max now, Let me know, I have one that has the RC Monster UBEC (the white one) on it already installed and a 12V fan installed too that is much more durable than the novak one that I could be interested in selling. |
I think the motor would hit the rear brace before the motor mount bottomed out.
I am running the 2.5D on 4s and stock 16/44 gearing. I dremmeled a couple fins off to allow clearance of the chassis brace. I wouldn't want to go lower gearing. after 1/10 scale electric racing we ripped my buggy around a tight track and the torque is great. if anything I'd like to gear up some for the bigger tracks but everyone that has driven it, and I have handed the controller to a lot of drivers now, just love how smooth and easy it is to drive. I changed the difs to 5k all the way and I found it helped bring the back around better for corners. I might thicken the center dif a little more next time but this setup is sure nice to drive. you'll find the RC8 very forgiving. best description I heard was it floats along like a cadillac. easy to correct in the air, even landing a jump on one wheel it seems to come down and be ready for throttle as soon as the wheels touch. I haven't done much to the stock setup at all other than difs.
Thanks Everyone for your help!! I cant wait to get everything purchased and installed :mdr:
@Cain I am thinking since I am so close to the release of the MMM I should probably just wait. I still have to order so much more stuff but I am hopping to get it done by the end of the month or early may. |
Question for you guys. How much does the center diff. help out with tuning? I would like to try direct drive but am not sure how much handeling I would lose.
I have one set up right now buts it a little slow and I am waiting on a larger kv motor. Goes about 30 I'd guess. |
It helps, but I can drive em either way honestly. It makes it alot less touchy on slick tracks to me (with diff)
| All times are GMT -4. The time now is 11:16 PM. |
