-   -   Anyone use RPM dual stage pistons yet? (https://www.rc-monster.com/forum/showthread.php?t=11193)
notnodak 04.04.2008 11:22 PM
I'm looking at them for my E-Maxx but am undecided.
_paralyzed_ 04.05.2008 08:15 AM
if you're using stock shocks don't bother, get better shocks, because eventually the caps will pop off. If you have aftermarket shocks, don't bother, you have plenty of room to tune with different weights of fluid, and should be able to dial in what you want with fluid viscosity.
notnodak 04.06.2008 12:53 AM
Thanks _paralyzed_, Have you tried these?
_paralyzed_ 04.06.2008 01:09 AM
nope, but I've blown lots of traxxas shocks, and even the racers don't change pistons, just springs and oil, what are you wanting to tune in or out of your shocks?
neweuser 04.06.2008 01:19 AM
I have had my emaxx for 6 years or better now (supermaxx) and have yet to change a piston. I can tell you if you are going with heavier fluid, the RPM's may be nice and drill the holes a tad bigger. From what I hear, this works well. But, like I said, I have yet to ever change a piston unless I was rebuilding the whole shock after a few years.
notnodak 04.06.2008 01:25 AM
I want to get more dampning and cushion but stay cheap. I have RCBros progressive springs also.
I had stock shocks on a heavier 3906 E-Maxx for two years and used Poerline springs on 4 and stock on 4. Not sure what oil vis it was. Is had allot more cushion on bigger jumps.
_paralyzed_ 04.06.2008 02:20 AM
just get heavier fluid then, stock is 30, try 60, also add some preload
