Polyquest Twenty Five 6000mAh
Hello,
Does anyone have an opinion on the "new" 25c Polyquest 6000mAh LiPo's? I just saw them on the HobbyLobby site (http://www.hobby-lobby.com/polyquest.htm). I'm running two 4900's to make one 4s pack now and I just don't have enough runtime to make a 15 minute main with warm up and really going for it. I'm thinking that with that extra 1100mAh I just may make it but I've not read much on Polyquest. Thanks. DM |
Well, Polyquest are made with enerland cells, so the packs should be comparable to flightpower, polyrc, etc. I am sure they are good packs, and worth the money.
Someone else who has run that pack may chime in. |
Can't comment on the 6k but I run the 5k version. Get probably 20 minutes of runtime with a 95amp motor. You must be pulling tons of amps for such short runtime?
DM |
12-15 minutes is what most guys I race with get as well, from 4s 4900mah in truggys. 1100mah's would probably get another 3 minsutes or so.
3 Minutes would do it...I figure that and a Nue and I should be able to finish those Nitro 15 Min mains.
DM |
I had one of the 4S 4900mah 25C packs. I got from my hard running about 15 - 20 minutes of runtime in an MBX5 with some Type R parts combined with a 1512 2.5D motor. When being more fluid with my driving, I could do more than 20 minutes
I think a lot of it depends on your driving style too. I am more of an on-power driver and power around the track, doing this though especially on winter tracks here (slick, hard) causes wheel spin pretty bad and burns up runtime. For me, I am looking into doing the PQ6000XP 25C, either 4S or 3S depending on some info I receive. As I could do 20 minutes with a maxamps 6000mah, and guys always comment on how much more efficient the 5000mah 4S is than the maxamps 6000mah, I believe I should easily do 20 minutes and more. (baddassrevo gets 25 - 30 minutes on his 8ight with a PQ5000XP pack). Drop me a PM if you are still looking for a place to order them from. |
| All times are GMT -4. The time now is 12:32 PM. |
