CRT Mechanical brakes or not?
This might be a dumb question, but do u have to use the mechanical brakes on a BL CRT? Cause with the center diff, it would direct drive and be able to use motor braking and have reverse, correct me if i am wrong.
You don't need the brakes. In fact, the brushless motor mount kit eliminates the extra servo mount to shave weight.
You can do both - the original setups dropped the brake for weight etc however the advance guard are going back to brakes for - front / rear break balance tuning and reducing the load on the esc/motor/batteries
| All times are GMT -4. The time now is 09:54 PM. |
