-   -   How do you guys mount your 9920 ? (https://www.rc-monster.com/forum/showthread.php?t=1132)
Mofomaxx 09.01.2005 05:30 PM
Just working out the layout for my BL MGT, new chassis on route (a steal off ebay) so i can hack away to my hearts content & mike is sorting me a centre diff, theres loads of room, got a few ideas on battery placement & i can keep the esc, rx, ubec, etc all on the centre line easy.... im looking at putting the ESC (probably the 9920) behind the motor on a nice flat bit of chassis but have noticed the 9920 looks basically just shrink wrapped, not what im used to with an ESC, so how do you guys mount it ? is it zip ties & double sided tape ? or has someone got a more technical answer ?
Pics greatly appreciated ;)
Cheers
Andy
El Jarretto 09.01.2005 05:57 PM
I use zip-ties. If you use double sided tape I would use servo tape. Other kinds just seem to peel off, you can also try velcro. I prefer to use velcro but in some situations you can't.
Dafni 09.01.2005 05:59 PM
I use velcro, servo tape or zip ties ..... or all at once:) A little padding won't hurt, because the electronic components on the bottom are just protected by the shrink. Some foam are whatever
Here's an old pic of my Revo, when I still had the 9L. Between the mount and ESC you would find a strip of thick velcro. I also use 2 zip ties on this one.
http://i18.photobucket.com/albums/b1...evoxxV1008.jpg
Serum 09.01.2005 06:14 PM
How did you get your motorclamp that black Daniel? a little scientific project named anodizing?
here is how i gave the 9920 place in a lightning;
http://www.serum.demon.nl/BL%20lightning%20PRO/16.JPG
http://www.serum.demon.nl/BL%20lightning%20PRO/17.JPG
http://www.serum.demon.nl/BL%20lightning%20PRO/18.JPG
http://www.serum.demon.nl/BL%20lightning%20PRO/19.JPG
(you shouldn't have asked for pics... ;) )
Dafni 09.01.2005 06:20 PM
:D Here we go again! Too bad the HB is not in your possesion anymore.
How did you get your Nemesis that silver?? A little project involving Sodium Hydroxide??
("nor really, but close" would be the answer to your question as well ;) )
Want some more pics of mine? j/k
Mofomaxx 09.01.2005 06:34 PM
Cheers guys, so my usual double sided velcro, a bit of padding & maybe a zip tie....... though serum, if you wanna knock up another of those mounts you made for the lightning ;)
Serum 09.02.2005 01:23 AM
@ dafni, no, it was a bit simpler than that.
I shorted the three wires, and put the shaft in a powerdrill. I used scotchbrite to remove the purple. It's about 4 minutes of work i guess.
dabid 09.02.2005 01:38 AM
I use a reusable zip tie on my Ofna 9.5's 9918, and Industrial Strength Velcro on my T2's 7018.
Dafni 09.02.2005 01:46 AM
Thanks Serum, I see. No big chemical magic involved, eh?
I just removed purple ano from a G1 Gorilla chassis, used a solution of NaOH. Worked like a charm.
Like I said in my first post. It's a good idea to use some sort of padding when you mount the ESC directly on the chassis of an off-road RC. A member here once damaged some components.
MetalMan 09.02.2005 09:33 AM
Yes, padding is NEEDED! I broke a part on the bottom of my Warrior 9918, even though I was using velcro on the bottom, and zip ties! Foam padding would be the best, IMO, along with zip ties.
Serum 09.02.2005 03:36 PM
Yeah, those SMD components are rather fragile..
I made foam inside the aluminum holder to prevent the smd horror
C.H.U.D. 09.02.2005 04:04 PM
I third, fourth, or fifth the recommendation of padding underneath.
Even though you have the ESC strapped securely w/ velcro or ties, there's enough vibration and bouncing to cause damage to the bottom.
