maxamps 10,000 mah loose cell??
well, this is a hard deal to pass up. $35 for a single loose cell, 10000mah. BUT, will it be good enough to blast a Neu powered Muggy to over 60mph?? I would build a 6S pack. here's the specs:
10000mah Capacity 3.7 Volts 59mm X 155mm X 10mm Maximum Continuous Discharge 100 amps Burst to 200-300 amps 200 grams I know it won't be the best battery, but wow would it be cheap! I don't have anything yet, so I know the question is vague, but what do you guys think? Can I hit 60 using a 6S with these cells? |
The cells are good for 100amps cont, so question would be can 2200 watts max get a muggy to hit 60mph? I do not think that the pack is goof enough. 8s may do it...
yeah, I had a feeling the answer would be no. oh well, had to ask! I didn't really want to build a lipo pack anyway.
wow.. that's a good deal...
Even @ 10C, it's not too bad... |
For an 8s setup in a big truck they would be good. Still lighter than the same voltage worth of nimhs, but not much!
I had a few packs, and at 4s they were not good enough to keep up with a 7xl. |
oh you might as well just run 8s 2p and you could get like 1 hour+ run time :diablo:
pardon my ignorance, but if you are just trying to get up to 60 for a speed run, not maintain 60mph for a period of time, wouldn't you use the burst amperage (they claim 200-300 amps) to figure top speed?
As I assume I am probably wrong, let me know so that I don't make the mistake again. |
Well if you were attempting to do speed runs, there would be no reason to use a 10,000 mah pack with the same amp rating as a 5000 mah pack anyway. Otherwise you are just adding weight. I bet a neu energy 4s 3300 mah 30c pack which costs the same amount will out do a 10,000 mah 10c maxamps pack, and it will be about a pound less weight. Maxamps cells are overrated imo.
Also, are you saying that a 4s neu will outperform a 6s maxamp? BTW, honestly when I posted before, I was just asking if when figuring out maximum watts, is it appropriate to use the continuous number and not the sustained or burst figures? |
Sorry, I didn't read the 6s part, but 4s or 6s, same deal... you are still better off with the lower capacity high c rate pack for speed runs. The maximum burst current for any pack is usually around twice as much as its continuous rating, but i wouldn't go by a packs burst rating because different companies measure them differently. e.g 10 seconds vs. 30 seconds.
| All times are GMT -4. The time now is 05:08 PM. |
