Deleted Nitro Parts when converting
Out of curiosity, I went through my 8ight parts manual and listed out all of the parts that get tossed when converting from nitro to electric. I also broke down the motor into it's individual pieces. There are close to 125 parts that are no longer needed and probably more that I didn't think about. Feel free to add to the list if I left anything out. The biggest thing I hear from nitro racers is that they like the sound, smoke and smell. All of that comes at the cost of many, many points of failure.
A9154 Motor Mount A9104 Clutch Bell Screw and washer A6949 Clutch Bearing x 2 A9117 Clutch Bell A9103 Crank Nut and Collet A9104 Clutch Shoe Posts x 4 A9108 Clutch Shoes x 2 A9107 Clutch Shoes x 2 A9114 Clutch Springs x 2 A9115 Clutch Springs x 2 A9165 Muffler Standoff (2 parts) A9160 Fuel Tank A4424 Fuel Tank Posts x 2 A9316 Fuel Line Clips Fuel Line Fuel Filter A6204 Tank Screws x 2 A6350 Tank Screw Washer x 2 A9313 Fuel Tank Grommets x 2 A9160 Fuel Tank Lid Pin A9161 Fuel Tank Lid and Spring A4422 Tank and Filter Guard A6277 Guard Screws A3541 Brake Shoes and Posts x 4 A3540 Brake Discs x 2 A4422 Splash Guard A9166 Brake Linkage A3544 Brake Cams x 2 A6109 Cam Clips A9150 Brake Clip A6227 Brake Linkage Hardware (23 parts) A6232 Screw A6254 Screw Throttle/Brake Servo A6206 Servo Screws x 4 A6277 Screws x 2 Air Filter Filter Assembly(5 parts) Muffler Exhaust Gaskets Header Header Springs Starter Box, Batteries and Charger Fuel Fuel Bottle Glow Driver and Charger Rx Battery Motor Crankshaft CrankCase Piston Sleeve Head Head Button Glow Plug Head Gaskets Needle Assembly (4 parts) Bearings x 2 Carb Body Carb Seal Carb Retainer Piston Pin Connecting Rod |
I'm sure sick of all those points of failure and having to clean my car so much. I can't wait for the MMM so I can finally finish my savage. Silly little things stuff you up with nitro like tonight I discovered a hole in my fuel line.
| All times are GMT -4. The time now is 12:33 AM. |
