New chassis for my t-maxx conversion...which one?
Hi all...I am about to order a chassis from Mike and can't decide which one to order. Any feed back...good and bad would be appreciated.
Thanks http://www.rc-monster.com/proddetail...LM16050&cat=45 http://www.rc-monster.com/proddetail...chassis&cat=17 http://www.rc-monster.com/proddetail...LM16040&cat=45 I will be using a center diff w/ a mount above the diff for the motor...hopefully Mike can make me one |
Imo
IMO since you are wanting to run a BL setup you might as well go with the FLM EMaxx chasis. Most of if not all of your TMaxx parts will interchange. I have one and it is a pretty good chasis for the money.
I was leaning toward that one...I saw that Mike had made a center motor mount above the center diff and the set up was on a the FLM E-MAXX chassis which the forum member did a great with. Which drive shafts do you use?
center mount came to me with driveshafts for $110
Choices
which transmission are you using?.. if using the T-Maxx, how will the motor be mounted...?
I will be using a HB center diff w/ an above motor mount...( as soon as Mike is available to make me one )
Well, get the E-maxx fastlane Chassis, lowered and extended...
| All times are GMT -4. The time now is 10:47 AM. |
