where do i buy them plugs for my hyperion charger?
just recieved my hyperion 0606i ac/dc and to my surprise, it did not come with them plugs to charge my batteires! the plugs im talking about is the black and red bullet connector that goes on the right side of the charger. im not even sure what their called so i dont know how to look for them so i can purchase one. can anybody help me out here...i prefer to get it at tower since my buddy is already ordering something from there, but anywhere will be fine...the cheaper place the better. i want one thats already assembled with the wires so all i need to do is install my dean connectors. i think i need 12g wires.
thanks for your help |
It's no special connector, pretty sure they're just any old banana plugs you could get from any electronics or hifi store. The better quality ones are gold plated and a tighter fit and can no doubt have less resistance (this is a good thing - go for expensive gold ones).
If you want to buy something already made up I'm pretty certain http://www3.towerhobbies.com/cgi-bin...&I=LXNCU4&P=ML will fit. FWIW 12ga is probably overkill for charging, I have the hyperion 0610i duo (12s 360W) and they recommend 14ga wires less than 200mm long. |
thats odd..my instructions for the 0606i recommended me 12g chare wires. oh well. i was just looking at those great planes one. tower doesnt say if they are 4mm banana plugs though so i need to make sure its 4mm so itll fit.
You don't "need" 12GA wires to charge. 14-16GA is perfectly fine (actually still overkill) for up to 15A charge rates as long as the wires are under 1 foot. |
great thanks guys. so that great planes one is 4mm confirmed?
y - np
PS leads should come in the box just without a deans on the end... You might want to give a call to the person that sold you it... |
from what i read, all the other models come with the wires except the 0606i, i guess its cus it the cheapest one they sell.
ill just purchase the great planes one. thanks for confirming it azjc. |
^^^^^ Ditto!! Was supposed to be there. My 1st Hyperion arrived with one of the end caps left off and I had to return the whole unit. The place I bought mine said they had seen it all from Hyperion, so there were no questions. |
hmm...in that case ill call them up tomo. thanks for the info.
so i called the company where i bought the charger from and they are sending out the charge leads. thanks guys !
| All times are GMT -4. The time now is 07:13 PM. |
