what is the difference between mamba micro1/18 and sidewinder micro 1/18?
how many amp for castle creations motor brushless 1/18(cm2042,2054,2068,2080) for continue and peak amp? Thank you for advance. |
I think the mamba one handle more amps.
But not 100% sure:neutral: |
There is the mamba micro pro, mamba 25 and sidewinder micro. The pro can handle more amps but the specs are a bit vague at the moment as it hasn't been released.
sidewinder micro is new name for mamba 25 which should be mamba 35 - they silently upgraded them a little while back to take more amps.
I would guess Pro is a bit like MM to sidewinder i.e. take more amps etc... |
| All times are GMT -4. The time now is 03:28 AM. |
