-   -   48 pitch pinions? (https://www.rc-monster.com/forum/showthread.php?t=11618)
asianplayer 04.25.2008 02:31 AM
48 pitch pinions?
I cant seem to find them on here, i need one with the 5mm bore but i just cant find one, i can only find the 32 pitch ones?
Sammus 04.25.2008 03:14 AM
I'd also like some, unfortunately I don't think theres much of a market for them... I think your best bet is probably drilling out a 1/8" on a lathe or a steady hand if your game :P
MetalMan 04.25.2008 03:25 AM
There is more of a use for them in the rock crawler market:
http://holmeshobbies.com/home.php?cat=8
Looks like 13t-15t.
_paralyzed_ 04.25.2008 05:14 AM
www.kershawdesigns.com has a good selection
dirt101 04.25.2008 06:44 AM
why not just change over to 32P? thats what I did on my rustler using a jato spur, and I couldnt be happier.
asianplayer 04.26.2008 12:03 AM
Ok actually thats not that bad of an idea but i need to find a spur that will fit my buggy. right now it is a 88 tooth spur with a inner diameter of aprox 4 mm so i need to find something that will fit that. Got any ideas on where i should look?, i was thinking tower since they have a good selection of spurs but most dont tell the inside diameter, so im going to need your guy's help on this.
dirt101 04.26.2008 12:24 AM
what kind of buggy is it?
asianplayer 04.26.2008 12:25 AM
its a 7 year old kyosho ultima rb, i know the stock parts arent being made anymore so thats why i'm trying to replace them with new parts.
dirt101 04.26.2008 12:26 AM
you could just take a tmaxx spur and then just drill new holes.
asianplayer 04.26.2008 12:29 AM
new holes for the imput shaft? i have a spacer that was made for teh car that is 4mm on teh outside, personally id rather use that then have to try and drill out a spacer, plus a tmaxx spur is to small, i feel a jump from 88t to just 72t is quite alot, but il give it a try.
dirt101 04.26.2008 12:30 AM
thats why you use a smaller pinion. if not its only like $3 lost.
asianplayer 04.26.2008 12:33 AM
no no, its not the speed im worried about its the spacing between the pinion and spur, i only have so much room, plus im using a xl motor which has a 5mm shaft, so everytime i want to switch pinions i need to order a new one, so thats why id rather have one 22t pinion and then mess around with spurs, which i thought would be easy to fine one, but is proving otherwise.
