-   -   here's a big pile of questions: need setup advice (https://www.rc-monster.com/forum/showthread.php?t=11647)
mk351e 04.26.2008 12:18 AM
OK, so just a quick refresh: I'm COMPLETELY new to BL; I'm coming from the 1/8 nitro world. I NEVER race, I just kinda bash a little, jump a little, drive on grass, parking lots, and sometimes go to a bmx trail and ride with my buddie's jato. NO racing, just messin around (not really bashing - I don't beat on my cars). I DO NEED to be able to at least go as fast as my italian big block nitro buggy, but I really want to be able to hit warp speed when I find an empty parking lot! :whistle: HOWEVER, I also want something that runs reliably, every time I use it, as in MINIMAL maintenance. Like a Toyota or a Honda :) I don't want to be monitoring/ worrying about temps all day long, hence, the Neu motor.
The vehicle is a Muggy. Yes, I know, not the best choice for high speed runs. That's ok!
I'm thinking something like this:
Muggy/ mech. brakes/ MMM/ 6S Zippy H 5000 mah/ Neu 15XX/ and a XXT pinion! I know, it's vague, but I made some progress.
Soooo, here's my questions:
1) will 6S get me to warp speed?? (~60mph?) Do I need more than 6S?? Is 6S a dumb idea, or am I on the right track?
2) any idea how much runtime I can expect from a 5000mah 6S??
3) which neu motor? I'm thinking 1521/1D (2900kv), but I'm not sure why. Maybe a 1527/1D (2300kv)? Or a 1515/1.5D (2700kv)?
4) is the MMM going to be enough?
5) what size pinion??
6) where do you buy these hyperion chargers? I can't find em, and RCM only has like 1 or 2. Where can I find the whole line?
Sorry for all the questions and hella long post, but I swear I'm making progress! :intello:
azjc 04.26.2008 12:33 AM
with a 6s pack I would go with a 1515/2.5d (1700kv) and the MMM will be plenty, expect upwards of 30mins of run time depending on your spur/pinion setup
jnev 04.26.2008 12:34 AM
1) 6s should be plenty. Its perfect for bashing.
2) It all depends on how you drive, but you can get about 40 - 45 minutes probably.
3) A 1527 will be way to powerful... you won't even be able to go full throttle, you'll just be wheeling all the time or break parts in the diffs/tranny. :lol: The 1521 and 1515 motors you mentioned has too high a KV in my opinion for that voltage. If you want speed but still be reliable, the 1515/2d would work well, or the 1521/1.5d. And they would both give you incredible speed.
4) The MMM will be perfect for this application. :yes:
5) Use this calculator to find the gearing you want: http://www.scriptasylum.com/rc_speed/_top_speed.html
6) Mike can sometimes special order them, but you can also buy them at maxamps.com or I am pretty sure amainhobbies.com also sells them.
Edit: He beat me to it.
dirt101 04.26.2008 12:35 AM
The MMM is unproven, but going by stats it should be nough. personally if I were you I would get a lower k/v 1521. somewhere around 2000k/v(I dont know the names).
60mph is fast and i think 55mph would be a better goal, but 6s is a good idea.
jzemaxx 04.26.2008 12:37 AM
What is warp speed to you??? Some people are happy with 50mph, some aren't. The suggestions so far are solid and you can't go wrong with a MMM.
jayjay283 04.26.2008 12:45 AM
lol i typed this up and got booted, always a dollar short and day late but seems alot of my opinions are close so Im not a total tard :mdr:
1. yes 60+ geared right, 6s will rip and is the MMM max., No, yeah
2. 25-35min depending on driving
3. All great motors but more 5s lipo motors IMO, id go with a slightly lower KV motor for 6s, since you have a muggy you will most likely be using 1 lipo brick ? you want the rpm to not be over 60k max and more around 50k for speed + reliability, multiply the volts x kv = rpm
4. more than
5. use the calculator to see the speed you want http://www.scriptasylum.com/rc_speed/_top_speed.html
5. maxamps.com has them for pretty good prices, but easily found by typing hyperion into a search engine or checking airplane/heli sites
I figured id throw in my 2 cents these are my opinions, this place is full of dudes who totally know what they're doing so I figured I'd start and they can tell me what a cretin I am
mk351e 04.26.2008 12:50 AM
ok, so my motor choice may be off, but what I don't understand is WHY? As in WHY do you choose one particular motor over another? ESPECIALLY with a Neu - I mean, you've got 15xx series, and there's say, 50 of them. Many have kv ratings very close, but they're different sizes, so WHY do you guys choose one over another???? I just don't get it! :cry:
Also, why don't I want those higher kv motors? they're gonna be faster, no? :mdr:
Why is picking out a motor proving to be so difficult for me??? It REALLY shouldn't be, should it?
mk351e 04.26.2008 12:53 AM
AHHH jzemaxx! I hoped you'd chime in! Your project is SICK (in a good way) with that there MMT truck!!!!!!!!!! But aren't you spinning your Neu motor past 60k?? and getting away with it?
Patrick 04.26.2008 12:56 AM
This thread could be relevant to you. http://www.rc-monster.com/forum/showthread.php?t=10316
This is the vid from that thread. http://www.youtube.com/watch?v=bo7GdkNpKAY
jnev 04.26.2008 12:56 AM
Yes higher KV = faster. But it also = more heat = and depending on how high the KV is, it could also = way to high RPMs.
Plug in all the values I linked you in my previous post. It will help you understand the differences in each motor.
jzemaxx 04.26.2008 12:57 AM
I'm spinning a 1521 to right at 71K. Not something I suggest doing, and neither does Steve over at Neu, but I don't care if they blow up.....lol. For someone that doesn't want to replace them often, run them 60K or under :yes:. Still will make TONS of power. Also the higher KV motors draw big time amps and will make less torque then a lower KV motor.
lincpimp 04.26.2008 01:05 AM
Ok, keep in mind that the longer can motors make more torque. It seems like mosty use a 1515 for a mt or truggy. Your muggy will most likely be heavier than a std truggy, so the 1521 may be a good choice for you. I would say that around 45k rpm is good for the motor, so at 6s lipo=22.2v you will want a 2000kv motor. 2000kv x 22.2 = 45k rpm (or so)
You battery choice sounds good, I would think that you will get somewhere between 25-30min with that pack, considering vehicle weight and gearing. Having the truck geared for 60mph may cause some issues during regular driving. I would say to have gearing setup for about 45mph regular, and have a larger pinion you can put in for speed runs. The lower gearing will cause less heat, and offer better runtimes.
jayjay283 04.26.2008 01:05 AM
lol jze, he not for racing, reliable just for goofing around... not drive it on an abandoned airstrip !! :rofl:
jzemaxx 04.26.2008 01:14 AM
Hehe, I'm all about flat out stupid speed. If its not faster then the speed limit, its boring....haha.
In all seriousness, a 1515 is probably more then enough. Most emaxx's are 12-14lbs depending on setup and the guys running the 1515's are flying and with the right gearing you can bash all day with no problems with heat.
Here is a video of a 1515 Emaxx on 6S......thats is sick fast across the grass.
http://www.youtube.com/watch?v=EoOlsYrUF5s
zeropointbug 04.26.2008 01:50 AM
Yes, i agree... I have a my setup which is running 7s2p A123 on a 1512 Neu 3D(1700kv.), so thats 23volts @ a hair under 40k rpm; and I was able to achieve 50mph no problem. The motor was still only 160F after a full run.
