Any Prelim info on gearing for E-Revo?
I am looking to pick up an E-Revo and combine it with a 4S or 6S brushless setup. What I am wondering is assuming a KV range (4S vs 6S) of 2700KV (4S) to 2000KV (6s), what pinions should be purchased for each of the setups?
Curious if anyone else has found out this info. |
you are looking at a lot of RPMs with the battery/motor pkgs if you did this you would need to get a quality motor(not a Feigao) and you will excessive wear on your drivetrain (diffs being the weaklink) |
Basing this off on what Castle is recommending for motors (2200KV for 6S), it will be a Neu of course.
No problem going to a slower motor though. |
If it helps, the Erevo uses the exact same tranny ratio and diff ratio as the new emaxx, so that should help people decide on what motor/gearing a little.
| All times are GMT -4. The time now is 01:39 PM. |
