Rustler gearing
I had the original 48 pitch gearing than I went to to the 32 pitch( jato spur) and thought that was a big improvement, I have since gone to MOD1, (Revo 40 tooth spur and 16 tooth pinion) and I like the gear geometry the best
With most vehicles mod 1 gears will be almost impossible to strip. Unless the mesh is way off. Some people have issues getting the mesh right...
I'm still with 48 pitch, but I run the CF HPI spur gears. Those things are nice and rigid so I don't get any flexing that I used to get with straight plastic spurs (made stuff strip when the gear would flex).
So far so good for me. |
I've used just plastic 48p spurs on my Rusty for quite a while, and have stripped quite a few. This was mostly due to having my slipper set real tight (was using old style slipper), but now I've replaced it with a REVO style one and loosened it a good bit. I only have problems when I jump real hard and it moves the motor out of place.
I would like to put 32 or mod 1 pitch on it, just so I never have to worry about stripping, but I can't find a small 32p pinion or a large enough spur to keep my gearing right (running Mamba Max 5700 on 3s and 4s A123 cells, geared 15/90, pretty much the sweet spot for my Talon tires, 20/90 for my Road Rages). Brijar!!! |
got any pictures of the conversion that you can put up?
wow, this is weird, im thinking about building a rustler, 10l,mm,4s 20/40 for 70 mph
| All times are GMT -4. The time now is 06:19 AM. |
