LSP - P Diff oil setup - HELP!
Just took the car apart and found the front and rear diff had no seals at all! Hence no oil!
So now the question is what to fill them with! I have 30k in the centre. In stock i only have 10k & 30k - What else should I get and what do I put in? Running a 1515/2.5D on 4s mm soon 6s mmm Thanks |
3k to 5k in the rear 7k to 10k in the front... oh and get some seals :lol:
I'm using 5k rear, 100k center, and 7k front
no wonder you cant keep the front down. hows that 100k, does it almost feel locked?
Its getting there. My front never came up last week when I ran it with buggy foams.
were you spinning alot? i put buggy tires on my emaxx before, and had constant wheel spin. it felt smooth and pulled straight, but the tires where spinning alot and i lost accelleration. also did you gear up any for it. i imagine you lost alot of topend if not.
Yeah, I'm having traction problems. I hope soaking the tires in stick it brown for a week will help that. I'm using a 25t pinion atm compare to 14t on the 40 series mashers. Truck is geared for 67mph atm.
| All times are GMT -4. The time now is 09:41 PM. |
