Darn...no over-volting the Monster
Hey people,
Just thought I should post some info from Patrick over on RCZ that I read. It looks like running over 6S LiPo on the Monster ain't gonna happen. Here's why: [There is] a 28.0V TVS (transient voltage suppressor) on the Monster Maxx -- so you will smoke the TVS with a 7S pack, and then smoke the whole controller the first time you do any serious braking with 7S. 6S is a hard limit. Nothing higher than 26.0V. Patrick Link: http://forums.radiocontrolzone.com/s...d.php?t=247907 He also said over on RC Groups that the switching BEC has a constant current rating of about 4A (runs warm) and peak of 5A. Should be plenty for our servos.:smile: It looks like he *might* be planning on an 8S version, and maybe a 12S controller down the line...but that's just purely my speculation. I just wanted people to know about the 6S limit, in case they hadn't read that and try to run their new MMM on 7 or 8S. Ain't gonna happen. :( |
Very good information. Looks like 7S A123 is doable tho. However my hyperion won't balance 7S. I still don't know why they make a 12S capable charger, and then only a 6S capable balancer. </rant>
I dont plan on going over 6s but still good information to know.
No fear boys :) I'm sure there will be tweaks and mods to get the MMM going over voltage. If it's only one component, I'm sure it will get modded properly.
I think most folks will find it sufficient on 6S (like me), but then again... |
Hmmm...such a disapointment. I've been waiting for this to come out and now it's extremely dangerous to run it over 6s.
I can under stand that, but then again- if it says 6s on the label, then 6s is all you can run; why call it 6s if its really 7~8s?... I think 6s2p of A123 will suit me just fine.
Well, they call the MM 3s, and it's usually 4s-5s no problem. I say we'll see what we see. 6s is plenty for me, but I'm sure people will be finding ways to push them farther.
The reason why CC said the Mamba Max could only do 3s is because 4s would push even the 4600kv CM36 motor over the 65,000 rpm limit. The ESC was clearly made for up to 4s, Castle Link has a cut-off for 4s... but you're gonna need a UBEC.
A solid 6s controller, and it is so cheap. Under $200 is unheard of for these specs yet. With any proper 6s or lower setup I really don't think I could overwork the ESC unless I got a 5B or a 25lb emaxx with super swampers.
I don't think there is a 7s hyperion balance adapter - I think you get a 3s and 4s adapter on the pack....
You link the 2 lba10's with a link cable and it will balance it as one battery... |
You can, other brands of packs also just have two balance leads hanging out.
what voltage is a 6s right off the charger? how about a 7s off the charger. maybe you could wait a while or not charge it to 100% capacity and the voltage would be low enough. Or am i just smoking crack?
personaly all i need it to do is 16nimh. then maybe some of those li-ion sony cells. in a 5-6s2p config |
| All times are GMT -4. The time now is 12:22 PM. |
