crt.5 ,building and tunning for speed help
:whistle: hi :na: just bought a crt.5 , im making it brushless , i allready had a mamba 4600 out of my rustler vxl .. but im unsure of the gearing because of the heat isues , ive just ordered the bore reducer and a 11t pinion .( i geuss i should have got 12 t instead ). but is there a better motor i should get instead of the cm36 motor fitted .. im after the most powerfull motor with good top end , and off the line power ..
its being powered by maxamps 5000 11.1v lipo,s.. plus any other mods are worth doing ..thanks for any help |
As far as mods go Mike sell a kit for your truck to lengthen the chassis and it comes w/ a motor mount...here's the link...http://www.rc-monster.com/proddetail...od=rcmcrt.5kit
Also, many forum members have a crt.5 so keep asking as far as the motor selection goes...I am not sure, but, I believe Neu makes a motor that would fit in there...again not 100% sure.....Welcome to the forums!:yipi: |
12T pinon would be to big, running a 4600 and 11.1v battery will be putting out 51060rpm which is probably to much for the little crt.5 and you will be having heating issues
| All times are GMT -4. The time now is 07:17 PM. |
