Compro 160/18 and new Emaxx...
I'm looking for settings for the Compro 160/18 for the new E-maxx. I have a low kV Neu motor hooked up as well and stock radio. I know the Neu is 4 pole and have already set the controller for that. I am running 4s lipos. I don't care about having reverse, so I can shut that off if it will help.
Right now I am getting erratic behavior (jerky acceleration). Could somone please provide me their settings so that I can try them out? Thanks. throttle min: neutral: throttle max: gear ratio: type of model: brake/deceleration: timing: range of neutral zone: automatic correction of neutral: freewheel: automatic brake in neutral: |
Jerky acceleration sounds like glitching, or possibly a loose connection between motor & esc somewhere....
Yeah, I actually do have what sounds and feels like glitching, where the steering servos make that glitching noise (constant jerky movement) and refuse to move for a few seconds.
I'll try switching radios to see if it helps. |
| All times are GMT -4. The time now is 06:04 AM. |
