-   -   question about Futaba FASST (https://www.rc-monster.com/forum/showthread.php?t=11914)
azjc 05.07.2008 10:02 PM
the reciever has a much shorter antennea, what has everybody done to set it up...do you still use a tube? Is one needed?
BlackedOutREVO 05.07.2008 10:17 PM
It isnt needed, but since its got the coaxial antenna it cant be bent to a right angle, so make sure its not bunched up all crazy, keep it curved
azjc 05.07.2008 11:08 PM
is it better to not use a tube than? Would it matter if you strapped it to the truck?
Blunten 05.07.2008 11:09 PM
I use the tube in mine and just tape it laying down on the chassis.
Sammus 05.08.2008 08:31 AM
I use a short tube, I cut a slit up the tube at the bottom so the antenna can exit a little early and I can still jam the tube in its holder hard.
BlackedOutREVO 05.08.2008 06:04 PM
Heres mine, the pic wasnt taken to see the antenna, so is not the best, but you can see how mine is, the tube is a few in long...
Run a tube IMO, just keep the wires with a curve, dont cramp them together
http://i128.photobucket.com/albums/p...O/IMG_3261.jpg
Cartwheels 05.16.2008 02:10 AM
you can heat up the tube where you want it to curve then when it cools it will stay that way.
