-   -   different type of HV problem.. (https://www.rc-monster.com/forum/showthread.php?t=1193)
alexrckid 09.11.2005 10:26 PM
anyone ever have a STUTTERING(not glitching) problem with their HV..??..........has run(in competition) fine until today. then applying quick throttle, the motor stutters and barely revs. but, when i slowly roll onto the throttle, it revs up completely. every connection has been triple checked. nothing loose and no frayed wires. not a gearing/thermal issue. batteries fresh and peaked. the symptoms are the same even with the pinion pulled. bottom line is that all of a sudden, the system seems to not like heavy, qiuckly applied throttle. not a binding, glitching of thermal issue........
RC-Monster Mike 09.11.2005 11:29 PM
Sounds like s ensor problem. I would send it back to Novak. They are pretty good with support.
coolhandcountry 09.12.2005 08:55 AM
My brother had that problem. It was his capictor. He put another one it and bam. Ran like it was new.
Serum 09.12.2005 03:02 PM
It could be the capacitor!
Because, the small pulses that the controller takes from the batts are a voltage killer for Nimh's/Nicds, they simple drop in voltage when they do.. You could try mounting a capacitor
RC-Monster Mike 09.12.2005 06:58 PM
True, the capacitor could be the trouble as well. It wouldn't hurt to try this first for sure.
