what's everyone's battery connector of choice?
I'm guessing deans ultra plugs. What do you guys use?
Deans for battery to esc, and either 4mm bullets or hard wiring from the motor to esc. On higher power setups I like to hard wire, one less thing to go wrong.
Mention was made about cleaning deans connectors from time to time, any suggestions on how to do this? |
I use deans for battery-ESC connections and 5.5mm bullet plugs for motor-ESC connections.
i use traxxas plugs, deans are to small and a pain in the a55 imo
If you're going to be pulling 100+ amps, some 5.5mm, 6.0mm, 6.5mm plugs would be awesome.... but my favourite are still Deans..
All of my Lipos use 6.0mm, and deans for all the NiMH batteries.... |
I was wondering about this too. I use a little wire brush and simple green on the male end. To afraid to touch the female ones on the lipos though. Any suggestions? |
Deans plugs
I'm using Deans plugs also.
5.5 bullet everywhere:wink:
5.5's and 4.0's to the motor and deans for the battery
I use a combination of Deans/5.5mm bullets for battery to ESC and 5.5mm to the motor in my BPP. The others are just Deans on the batteries and 4mm and 3.5mm bullets on the motor.
man alot of deans, those things are a pain in the a55 imo, to small for my meaty fingers lol
Depends on the current. Deans for anything that's going to draw ~30A continuous/100+A peak. For higher currents, either direct solder or 5.5/6mm bullet connectors.
The bad thing about bullets is that they are harder to "key" to prevent misplugging. And even if you do alternate the male/female ends, the battery side connectors can accidentally short on something when disconnected. Deans really should make a larger connector. Make it the same way, just a little heftier and a little longer to make it easier to grip. |
| All times are GMT -4. The time now is 04:00 AM. |
