Central shaft of G3R
Hi,
I would like to ask the length of central shaft for replacement. Are they 110mm in front and 72mm in rear? By the way, does anyone have experience using stock revo drive shaft for the central shaft of G3R? How are they holding with neu motors? |
Hay Gallagher!!
I don’t use the T-Bones so I cant answer your first question.. But I do use the stock Traxxas 3905 E Maxx drive lines in my GR3 and my G3.0, both of my trucks have a Nue motors. GR3 has a fast lane single speed and a 3905 E Maxx trans in my G3.0, with RCM buggy 1/8 diffs in both of them, so yes they are being tested.. So far no issue at all.. Here is picture of them installed in GR3. http://i264.photobucket.com/albums/i...7/IMG_2419.jpg And their Cheep to use!!! just buy two rear 3905 drive lines and mod / cut them to proper length, Mike even sells the 1/8 diff adapters for almost noting, http://www.rc-monster.com/proddetail...coupler&cat=44 the total investment should put you back $35 Hope that helps.. Have a great one Shaun. |
| All times are GMT -4. The time now is 12:31 AM. |
