Hyperion EOS 0610i duo
Im in need of a good charger and dont really mind spending money if its a one time deal (good charger that lasts long) Question I had was is there a better charger then the Hyperion duo? My needs are basically going to end up with the need/want to charge 12S, Any info is much appreciated also what chargers do you guys run and what chargers do you want/going to buy?
I love my duo. Now I can run and charge dual packs like nothing, so I can buy a few 3s and 2s packs to do it all from 2s to 6s. Also very handy for matching packs or cells, as it tells you the IR. Just be sure that your charging leads are the same, as a longer lead will show a higher IR.
Any one out there use something different then the hyperion? |
I use the MRC Superbrain 989, and although I love it and it is a great charger, I wish it was a little more powerful. For example, when I charge my TrueRC 4s 8000 pack. I set it to 8 amps, but it can only charge it at about 7.1 amps... I am actually planning on getting the 610DUO in the future, if the funds allow. But if I were choosing now, I'd go with the DUO. :yes:
^^ thank you very much, I am just checking that im buying a good charger. There are sooooo many options out there to choose from :)
your PS could be under powered, which one are you using? |
yea im thinking about investing in a better chargerright now i have a eos 5idp andits good, but it only goes to 5 amps, and my 2s2p 8000's take about 3 hours on it lol i have to restart them, as it only puts in 5500ah at once
Good info guys and thank you!
| All times are GMT -4. The time now is 11:35 PM. |
