What batterys are u guys running with ur losi 8T truggys?
Originally Posted by austinelse [View] Fact: It is the motor and gearing that determines the amp draw, not the speed control. There is no way to determine if a battery will work with a specific speed control without knowing what the amp draw of the motor is. There is no answer to the question "What batteries can be used with the MMM?" since you do not know the amp draw of the motor... -Austin I will run 5s an 4s on my MMM BUT, ive been running a 3s2p 8000mah pack for about 5+ months on my setup geared for low-mid 30's..... (8T truggy, Neu 1515 1y/f, mamba max(run mid to low settings in the mm software/low to lowest timming, 70%-40% limit(never under 30%), ) now my truggy has been running great an can last 20mins(its no speed demon) but this the setup ive been running on a SMALL clay/dirt track with my Mamba Max, an hasnt thermaled 1 time... can i run my 3s2p 8000 pack, the same way with the MMM? my 8T truggy just doesnt drive rite with a HEAVY BATTERY! with my 3s2p 8000 i can put alittle weight here or there too fine tune. i dont want too run packs that are NO MORE THEN 650-700grams.... btw those of u with 8T's what battery are u runnning??? (do u find it too heavy or good?) (also what battery are u thinking of running/getting when u get ur MMM?) |
| All times are GMT -4. The time now is 08:41 AM. |
