Want To Test The MMM
Hi guys.....
So I have the MMM sitting here waiting on a motor selection, going in an E-Maxx for hard bashing. I'll be using 2 2s 8K Maxamps in series, for now anyway. If I hook it up to the stock Titans (actually the $3.50 knock offs) will I be able to tell if I have a good on or bad one? I'd rather wait for the motor and a MMM at the same time then wait for a replacement MMM (if need be) after waiting for a motor.:lol: Thanks |
Test It.
You might as well test it now and find out if the MMM is going to hold up or not. If it fails you can get right on that and get a replacement for it. Best of luck with that.:lol:
I suggest you hook the thing up to a motor and beat the snot out of it:intello:
That's the idea:wink: If I do have one of the bad ones just want to make sure this set up will work:smile:
You proly know this but make sure you set the ESC to brushed mode. Also remember to set it back to Brushless when you put the brushless motor in. I forgot to set a MM back to brushless once and i cooked it! |
Can you remind me again when I get a brushless motor:lol: |
I am sure the titans can handle 4s, they are 23turn 550 motors.
They didn't do well with extended periods of full throttle, hard braking and cookies on wet pavement:whistle:
When wiring the two motors to the MMM do I connect both reds to red and both blacks to black? |
I run the traxxas titan 12t from the xl5 rustler/pede on 3s all the time. They are really good motors, and cheap too. I still have a few brushed vehicles, but they are all lipo powered now! |
| All times are GMT -4. The time now is 12:30 AM. |
