how will a lrp 4.5 vector do in a rusty?
i can get one for cheap just wondering if it will be better than the vxl can, will it work with the vxl esc, im wanting to lower temps now, might get a mm to go with any input:neutral:
o i was wondering being a 4.5 turn, the vxl is a 3.5 correct? i know its 3500kv, so 3s would be a no no for the lrp huh?
Good 2s motor, but that's about it. Probably best if you intend to race, and I'm sure you'll be wanting more torque after you're done with the novelty of having the 4.5 turn motor for bashing though. Getting a fast motor is unnecessary for racing. More often than not, you probably will turn better lap times with a turn or two higher motor.
I've read a 50/50 chance of the sensor port working well, or it just conking out, but who knows, maybe that issue is fixed with more recent VXLs. If you have the VXL setup and can afford to run 3s, that's probably a far better option overall. The VXL is a 10 turn motor btw. |
So the lrp would require less gearing than the vxl to do the same speed, but would most likely draw more current and run hotter. |
ah ok well i guess ill just gear down, thats what im doing is racing it, and after a pack its esc 190, motor 220! geared 25/86
| All times are GMT -4. The time now is 03:30 AM. |
