Mamba Max and Castle link?
Has anybody tried programing a Mamba Max with a castle link instead of USB port? Every time I mount my MM with the caps down wind of the heat sink or an orientation to make the wire reach the motor the darn USB port gets blocked by something.
Thank you.
Nope, I second the fact it doesn't work. I tried too. Would've been nice though...
Maybe the next evolution of the MM will allow for it, Possibly eliminate the usb port. The use of the castle link would eliminate a possible weakness in the MM, water shorting the usb port
I think I read somewhere from Castle that they won't be using the USB port for the next MM, causes to much issues and No, it doesn't work
| All times are GMT -4. The time now is 02:11 AM. |
