-   -   wut to replace the stock slipper? (https://www.rc-monster.com/forum/showthread.php?t=1227)
Shadow350Z 09.15.2005 10:35 PM
as the title says
wut do i replace the stock 70T slipper with?
RC-Monster Mike 09.15.2005 10:56 PM
I recommend the Strobe slipper as a replacement/upgrade. It takes bigger, tougher gears and has the ability to dial in some slip, unlike the stock setup.
Shadow350Z 09.15.2005 11:42 PM
thnx Mike
can i get a linky??
to the best and not a wallet burner
Serum 09.16.2005 02:12 AM
http://www.rc-monster.com/proddetail...od=Slipper-Kit
It includes the bearing.
coolhandcountry 09.16.2005 04:07 PM
If you go to the strobe. Don't you have to change the pitch to mod 1?
Serum 09.16.2005 05:19 PM
Yeah, that's the reason why Mike reccomends it.. Mod 1 is much stronger than a 32 ptich..
coolhandcountry 09.16.2005 05:29 PM
The strength part sounds real good. Just seems the selection of spurs are limited. I still running the 32 pitch for this reason. I have to change up. ONe day.
Shadow350Z 09.16.2005 10:45 PM
so means i need to change pinions too?
wut pinions should i use??
that i can get at my LHS also can fit a HV-MAxx
Serum 09.17.2005 03:56 AM
You probably can't get them at your lhs, it are mod 1 pinions.
mt_enthusiast 09.17.2005 10:48 AM
I ran the 1/8" mod1 pinions from Mike with the 51T Ofna spur on the HV-Maxx. You really need to watch the final gear ratio recommended by Novak. Before replacing the HV-Maxx, I originally geared 1st speed to be in the recommended gear ratio and never used 2nd.
Shadow350Z 09.20.2005 06:01 PM
will robinson racing double disc be good replacement??
coolhandcountry 09.20.2005 06:06 PM
The robinson does nicely. IT is not the strobe system. It does run the 32 pitch though.
Shadow350Z 09.20.2005 06:29 PM
so how doe the robinson work??
does it stil use sliper pegs?
coolhandcountry 09.20.2005 06:37 PM
No slipper pegs. It uses disk. Hold alot better than pegs.
RC-Monster Mike 09.20.2005 08:08 PM
The Robinson is a step above the stock setup, but a couple steps below the Strobe. With high power, the Robinson slipper is inconsistant, and the spur gears are rather soft. The Strobe offers more durability, consistency and tuneability.
