jammin X1 crt middle gear
Who makes a nylon center gear for the jammin x1 crt? How many teeth are on the stock medal gear? I've converted to electric and don't want to use the medal gear.
Rob |
Welcome to the forum.
You can use a 46t kyosho spur, it will fit the center diff cup. It is smaller than the stock spur, and you will have to use an 11-13t pinion, depending on the motor used. |
Thanks lincpimp You wouldn't happin to have a part # would ya..
Thanks |
Heres a link to it: http://www.rc-monster.com/proddetail...YOIF148&cat=40
I recommend the 48T metal buggy gear for the CRT instead of the 46T kyosho plastic. It's small yet bullet proof. My 2 cents.........
| All times are GMT -4. The time now is 12:39 AM. |
